Page 1 of 1
sddsplot can leave zombie process.
Posted: 07 Jul 2013, 23:23
by femanov
it is possibly wait() for pipe input.
Not a big problem, but should be corrected because process table is'n infinite size.
Re: sddsplot can leave zombie process.
Posted: 21 Aug 2013, 12:00
by soliday
If you are launching sddsplot from a tcl/tk script you can end up with zombie processes. The parent processes (tcl/tk script) launches the sddsplot processes which in turn launches the mpl_motif processes. mpl_motif is the graph window that you see. Normally sddsplot is executed in the background so that the tcl/tk script doesn't hang until the mpl_motif window is destroyed. The command might look like:
exec sddsplot data.sdds -col=x,y &
In this case, you will get a zombie process. sddsplot will have completely exited but it will still be listed in the process tree. Even closing the mpl_motif window will not remove it. The zombie process will be removed once you close the parent tcl/tk script.
There is a workaround for this in tcl/tk that I just learned about. You could run:
after 10000 { exec sleep 0 }
This will cause the script to launch another program 10 seconds after sddsplot was launched. Some internal mechanism inside tcl/tk apparently checks on the state of all it's children processes and will purge the zombie sddsplot process.
