Page 1 of 1
Version 2025.3 released
Posted: 24 Oct 2025, 13:54
by michael_borland
Version 2025.3 has been released. Changes are detailed in the manual.
It includes several bug fixes and enhancements, the most significant of which is the addition of intrabeam scattering calculations using the diffusion matrix approach of Kubo and Oide.
Re: Version 2025.3 released
Posted: 19 Jan 2026, 13:33
by Slava
Dear all, I faced a problem concerns module of correction.
It is not run correctly on Windows 10/11 with the latest Elegant version.
Two archives are attached. One for elegant usage and another one for Pelegant usage. There are log files in the attachments.
Note that the attached files were correctly treated by the earlier version of Elegant.
What is happened?
Posted: 20 Jan 2026, 10:54
by soliday
I see this issue has been fixed for the next release. I will post a pre-release version here with the fix in a few minutes.
--Bob
Posted: 20 Jan 2026, 11:44
by soliday
You can download the pre-released version here:
https://ops.aps.anl.gov/downloads/Elegant-x64.alpha.msi
Since this is not technically ready for release yet, you may find other problems. If you do, then you can download the previous releases here:
https://ops.aps.anl.gov/downloads/Elega ... 2.2025.msi
https://ops.aps.anl.gov/downloads/Elega ... 0.2025.msi
Posted: 04 Feb 2026, 04:33
by Slava
Thanks a lot.
Nevertheless, I found that &subprocess command does not work under Windows 10 & 11.
Command like
&subprocess command = "sddsplot -columnNames=s,betax lattice.twi" &end
is not executed correctly.
