Bend with misalignment
Post Reply
tiansk
Post by tiansk » 10 Oct 2019, 05:09
Hi Michael,
I confirmed the transmission model of bend with single particle tracking,when I set the DX of CSBEND with different values,the output as show in the uploading attachment。The particle initial coordinate at entrance is [0 0 0 0 0 0],the coordinate at exit is plot in the attachment.The intuitive idea is that the misalignment DX doesn't affect the particle exit coordinates,should I need to set some parameters of CSBEND?
Contact:
Re: Bend with misalignment
Post by michael_borland » 10 Oct 2019, 14:32
Assuming the dipole has no gradient (K1=0) or other multipole content, the most likely explanation is that you have E1=0 on the dipole, which means sector focusing is present at the entrance. The the dipole misaligned in x, it is like having an offset quadrupole, which delivers a kick to the beam. It is only for a rectangular dipole (E1=E2=ANGLE/2) that one expects this effect to go away.
tiansk
Post by tiansk » 10 Oct 2019, 19:04
Hi Michael,
I set the E1 and E2 in CSBEND (E1=E2=ANGLE/2),I upload the files I use!The command used like this:
elegant bend.ele -macro=L=1.0972538663939300,ANGLE=0.0238688451731700,E1=0.0119344225865850,E2=0.0119344225865850,DX_B1=0.0003000000000000,DY_B1=0.0,DZ_B1=0.0,TILT_B1=0.0,DX=0.0,DY=0.0,DP=0.0,DXP=0.0,DYP=0.0,N_KICKS_B1=1000.0,EXPAND_HAMILTONIAN=1
We could change the DX_B1 value!
bend.lte
(195 Bytes) Downloaded 202 times
bend.ele
(1.37 KiB) Downloaded 220 times
Contact:
Post by michael_borland » 10 Oct 2019, 22:03
I cross-checked with the NIBEND element and got very close results. I think it is correct.
Since the misalignment is performed in the frame of the entrance coordinates, it might not behave the way you expect.
bend.lte
(232 Bytes) Downloaded 221 times
Post Reply
