JoelFrederico
Post
by JoelFrederico » 06 May 2011, 15:53
I've noticed there's a strange crash at the end of this simulation:
Thanks for using Pelegant. Please cite the following references in your publications:
M. Borland, "elegant: A Flexible SDDS-Compliant Code for Accelerator Simulation,"
Advanced Photon Source LS-287, September 2000.
Y. Wang and M. Borland, "Pelegant: A Parallel Accelerator Simulation Code for
Electron Generation and Tracking, Proceedings of the 12th Advanced Accelerator
Concepts Workshop, 2006.
If you use a modified version, please indicate this in all publications.
*** An error occurred in MPI_Barrier
*** after MPI was finalized
*** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
[oak068:26519] Abort after MPI_FINALIZE completed successfully; not able to guarantee that all other processes were killed!
[oak068:26520] Abort after MPI_FINALIZE completed successfully; not able to guarantee that all other processes were killed!
mpirun has exited due to process rank 1 with PID 26518 on
node oak068 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
TID HOST_NAME COMMAND_LINE STATUS TERMINATION_TIME
0001 oak068 mympirun_wrapper Exit (1) 05/06/2011 13:47:48
0002 oak068 mympirun_wrapper Exit (1) 05/06/2011 13:47:48
It seems to have something to do with the run_control settings (possibly first_is_fiducial), although I can't seem to figure out exactly what's triggering it. It doesn't seem to be a huge problem as far as the sim goes, since I haven't had a problem with the final data being written, but my guess is it's not cleaning up correctly.
http://www.stanford.edu/~joelfred/Peleg ... ier.tar.gz
ywang25
Post
by ywang25 » 06 May 2011, 16:06
Joel,
It appears the memory is not handled properly somewhere in the code.
Can you check the file you uploaded? I downloaded and got 0 byte.
Yusong
JoelFrederico
Post
by JoelFrederico » 06 May 2011, 16:14
Sorry, went over my quota. It should be there now.
ywang25
Post
by ywang25 » 11 May 2011, 08:56
Joel,
I tested your example on two clusters: both have Red Hat 4.1.2 installed. One test uses MVAPICH2 1.4.0rc1 with Infiniband network and the other uses MPICH2 version 1.2.1. The problem your described didn't show on both cases. I also used a memory debugger and it didn't report any problem for this simple simulation.
In both tests, the Pelegant is built natively on each of the clusters. I am afraid there could be minor portability issue if the environment you ran is not the same as where Pelegant was built.
Yusong
JoelFrederico
Post
by JoelFrederico » 17 May 2011, 18:16
Thanks, Yusong,
Pelegant was compiled for this system, it's using NFS for the file system, and OpenMPI with Infiniband for communication. Since it's not causing problems in the simulation as far as I can tell, I won't worry about it. It seems reproducible with given settings, but I haven't really invested in finding which setting causes it. I'll let you know if it becomes a problem or I find a pattern.
JOel
