Pelegant &sdds_beam issue
Post Reply
ZeYu
Post by ZeYu » 03 Mar 2025, 04:19
Hi,
I tried running the provided file with Pelegant, but now I have encountered an issue. I attempted to use the &sdds_beam command in injection2.ele to read the particle coordinates, but it does not seem to execute correctly. However, the program runs successfully in elegant.
The error message is:
Opening file "beam injection.sdds'
MPI File open failed: other I/o error , error stack:
ADIO RESOLVEFILETYPE FNCALL(78): 0ther I/O error Input/output error
Sincerely,
Ze Yu
pelegant.zip
(235.02 KiB) Downloaded 3428 times
Contact:
Re: Pelegant &sdds_beam issue
Post by michael_borland » 10 Mar 2025, 18:57
I tried this and it ran without any issues on Pelegant. Is there another filesystem you can try?
Which operating system are you using?
Post Reply
