R56 and momentum chirp definition in elegant
Posted: 22 May 2019, 10:43
Hello Michael,
I have confusion about the definition of R56. I can get the R56 fromĀ .mat file, which is an element of the transport matrix. Second, I can calculate it by particle tracking (.sig file): R56 = s56/s6*s6.
If I give some positive value of momentum chirp in the &bunced_beam, then I found different R56 from above methods. Technically, it seems correct because of <s*delta> corelation, but R56 is a beamline property so I would expect it to be same as obtained fromĀ .mat file. Could you please help me if I am mixing/missing something?
Aamna
Aamna
