Hello Michael,
I have confusion about the definition of R56. I can get the R56 from .mat file, which is an element of the transport matrix. Second, I can calculate it by particle tracking (.sig file): R56 = s56/s6*s6.
If I give some positive value of momentum chirp in the &bunced_beam, then I found different R56 from above methods. Technically, it seems correct because of <s*delta> corelation, but R56 is a beamline property so I would expect it to be same as obtained from .mat file. Could you please help me if I am mixing/missing something?
Aamna
R56 and momentum chirp definition in elegant
- Contact:
Re: R56 and momentum chirp definition in elegant
Aamna,
The relationship between s56 and R56 is as follows
so if you want to compute R56 from beam correlations, you need to use
Code: Select all
s56(end) = s56(beginning) + s6^2*R56
Code: Select all
R56 = (s56(end)-s56(beginning))/s6^2
