How to change the name a column?
Thanks a lot!
a question about SDDS
Re: a question about SDDS
You can change the name of a column, parameter, or array using sddsconvert:
sddsconvert input.sdds output.sdds -rename=column,oldName=newName
You can also change many names at once using -editnames, e.g.,
sddsconvert input.sdds output.sdds -rename=column,*y,%/y/z/
would replace 'y' with 'z' in all columns ending in 'y'.
