multi-type rows extraction with sdds toolkit
Faissal
Post by Faissal » 23 Jan 2018, 06:23
Apologies if this question might sound trivial for some of you. I have the following situation:
There is a twiss file with several columns, "s", "betax", "betay", "ElementType" etc
I first extract the lines of the file that correspon to quadrupole values, and it works. I do (in an elegant file)
&subprocess
command = "sddsprocess run0_test.twi jan18.betaxTerms  -match=col,ElementType=KQUAD "
However, if I want to extract the line KQUAD lines **and** the KSEXT ones in the final output, I try
&subprocess
command = "sddsprocess run0_test.twi jan18.betaxTerms  -match=col,ElementType=KQUAD,ElementType= KSEXT, | "
and it doesn't work. The notation I tried is inspired from the SDDStoolkit manual, p.136 . I don't really see what I am doing wrong.
PS: i am extracting the KQUAD and KSEXT values to have more point for the KQUAD optimization.
Re: multi-type rows extraction with sdds toolkit
Post by michael_borland » 23 Jan 2018, 09:32
Faissal,
The syntax is a bit off. Try removing the spaces, i.e., use
&subprocess
command = "sddsprocess run0_test.twi jan18.betaxTerms  -match=col,ElementType=KQUAD,ElementType=KSEXT,| "
instead of
&subprocess
Faissal
Post by Faissal » 29 Jan 2018, 08:35
thank you for having pointed out the blank to my attention. I did some further trial and errors and managed to make things work, by writing:
(inside an *.ele file)
&subprocess
command = " sddsprocess input.twi output.sdds  -match=col,ElementType=\"KQUAD,ElementType=KSEXT,|\"   "
or, as a standalone command in the shell:
sddsprocess inpit.twi output.sdds  -match=col,ElementType="KQUAD,ElementType=KSEXT,|"
I must thank you because without the step you provided I wouldn't have been able to find the error.
To be honest, I find my own final version a bit strange, because the apostrophes include the second "ElementType" and not the first, if you notice. But it clearly works, as I checked by converting the output sdds into a csv for easier browsing through. Could it be that the syntax in the SDDStoolkit manual correspond to an earlier version perhaps? Because the syntax of the manual was giving me "Invalid null command" until I implemented the above modification.
regards,
- Faissal
Post by soliday » 29 Jan 2018, 10:36
If an option has special characters like | or spaces, I usually just quote the entire option:
"-match=col,ElementType=KQUAD,ElementType=KSEXT,|"
Post by michael_borland » 29 Jan 2018, 12:12
I agree with Bob, it is best to quote the entire string.
Faissal
Post by Faissal » 31 Jan 2018, 05:37
Many thanks Michael and Bob !
regards,
- Faissal
