I want to know the meaning of the parameters, START_PASS and END_PASS, of the element RFDF. I read the manual, but I couldn't figure out their meaning. Could you explain the description in more detail?
Thanks
Gunn
meaning of element (RFDF) parameters
Re: meaning of element (RFDF) parameters
Gunn,
These parameters are intended for use in ring simulations, where the beam goes around many turns ("passes" in elegant's lingo). They allow gating the cavity on and off. So if you want to have the cavity turned on only for passes 10 through 20, you'd use
START_PASS=10,END_PASS=20
