Terminated by SIGSEGVProgram - for all files
tcharles
Post by tcharles » 08 Sep 2017, 07:29
I've set up a Virtual Machine to run elegant on a cluster. I've successfully installed elegant (version 33.1.1) however I'm getting the error, "Terminated by SIGSEGVProgram trace-back:".
The files I'm using work on the versions of elegant I have installed on a MAC OSX and a windows machine, however not on the linux VM. Any ideas? I've tried using some of the Elegant example files and get the same error, so it's not specific to the files I don't think.
Thanks in advance!
Tessa
Re: Terminated by SIGSEGVProgram - for all files
Post by soliday » 08 Sep 2017, 08:01
There is a related forum post in the Bugs category. There is a new minor release 33.1.2 to fix this problem. I only had time to post new binaries for Windows and MacOS. You can build your own RPM using the
http://www.aps.anl.gov/Accelerator_Syst ... d-AOP-RPMs script. I will try to update the prebuilt Linux RPMs today.
Post by soliday » 08 Sep 2017, 11:31
The new RPMs for Linux are posted.
tcharles
Post by tcharles » 11 Sep 2017, 04:07
Thank you!
