run_setup very slow for very long beam line.
Hi, Michael
I generated a quite long lattice and the run_setup takes 8 minutes to finish. Below are the output of run_setup:
Seeding random number generators
length of beamline START_TO_END per pass: 9.175199952533640e+04 m
statistics: ET: 00:07:57 CP: 476.88 BIO:0 DIO:0 PF:0 MEM:0
Is that normal to take so long time to read the lattice in?
Yue
Yue
Re: run_setup very slow for very long beam line.
Yue,
Sorry for the delayed reply. I've been away and very busy since returning.
It is not expected to be that slow. I tried a lattice much bigger than that just now and it took only 5 seconds. Can you upload the lattice so I can have a look?
It would be great if you can take a look. Please find the lattice file in attachment.
Also the run_setup is :
&run_setup
lattice = test.lte,
p_central = 12958.9317133,
rootname = 1KPartRAD_MLIGN_1um_CENTER,
centroid = %s.cen,
sigma = %s.sig,
use_beamline = start_to_end,
Thanks a lot.
Yue
&run_setup
lattice = test.lte,
centroid = %s.cen,
sigma = %s.sig,
Thanks a lot.
Yue
- test.lte
- (1.24 MiB) Downloaded 496 times
By the way, I am using the macos binary, version 26.0.2.
Yue,
I was able to improve this dramatically by using a hash table for some of the lattice parsing. The change will appear in the next version, which I hope to release next week or early in January. If you build from source, I can give it to you sooner.
Thank you so much for the great news. I hope to use it ASAP so if the source is available, please let me know.
Yue
Yue
Yue,
Here's the modified source file. It should build if you replace the existing file of the same name. Let me know of any problems.
- get_beamline.c
- (44.37 KiB) Downloaded 487 times
Hi, Michael
I recompiled elegant and the improvement is drastic. Thanks again.
However I failed in compiling Pelegant, with error on missing libSDDSmpi. Do I need any change when I compile SDDS for mpi version?
Yue
Yue
Yue,
It should work if you do the following:
I'm assuming you have oag and epics in your home directory. If not, adjust accordingly.
% cd ~/epics/extensions/src/SDDS/SDDSlib
% make MPI=1
% cd ~/oag/apps/src/elegant
% make Pelegant
HI, Michael
I compiled the Pelegant without errors. However when I run it, I got errors:
table structure size is inconsistent
Error:
passed size is not equal to expected size for SDDS_DATASET structure
Passed size is 536, library size is 528
Could you advise on where this error comes from?
Yue
Error:
Yue
