Computation of the bunching factor
headdoggy64
Post by headdoggy64 » 15 Sep 2014, 11:10
Hello all,
Just wondering, if there is a standard way in Elegant/SDDS to compute a bunching factor:
n(\omega) = \sum{\exp{ I \omega t_i}}^2
I tried to search the forum, but haven't found it.
Thanks.
Re: Computation of the bunching factor
Post by michael_borland » 15 Sep 2014, 16:49
Sorry for the delayed reply. I was on vacation.
You can use the program sddsprocess to compute the bunching factor:
sddsprocess output.sdds -pipe=out -define=parameter,omega,1e10 \
  "-define=col,CosWt,omega t * cos n_rows /" "-define=col,SinWt,omega t * sin n_rows /" \
  -process=CosWt,sum,ReB -process=SinWt,sum,ImB \
| sddsprintout -pipe -parameter=??B
Presumably a histogram followed by an FFT would give you the bunching factor vs omega, but you'd need to watch out for numerical factors. Use sddshist followed by sddsfft for this.
Post by michael_borland » 06 Apr 2015, 15:08
N.B.: a future release (before summer 2015) will include a program (sddsbunchingfactor) to compute bunching factors.
headdoggy64
Post by headdoggy64 » 04 Nov 2016, 15:10
Hello Michael,
Is it possible to add a possibility of computing the full three dimensional bunching factor of the distribution?
(For example, using Eq. 2.15 from http://www.slac.stanford.edu/cgi-wrap/g ... -r-576.pdf)
The bunching factor will then depend on the angle \theta, which will be the angle between the detector position and the beam axis.
Thank you,
Alex
