Dear Micheal Borland
Thanks! It is working.
I think the significant number in my code made this issue.
I will carefully make the field map with well defined significant number.
Best regards
Ji-Gwang Hwang
3D B field map
Re: 3D B field map
I have a follow up question to this discussion. In our setup, the quadrupoles are close to each other that their fringing fields overlap. In some cases there is a collimator standing too close to the magnet in its fringe. Are these scenarios dealt well in elegant (I am using BMXYZ to import the maps), or should I expect some deviations? Also I would like to know which one of the integration mode would you recommended in general?
cheers
Neeraj
cheers
Neeraj
-Neeraj
