Implementation of bunch lengthning and transverse impedance
Aamna_Khan
Post by Aamna_Khan » 22 Feb 2021, 14:00
Hello Michael,
I’m studying the head-tail instability for NSLS-II by taking into account the intensity-dependent (zlong) bunch lengthening.
To do this, I tried to implement the initial bunch length obtained from zlongit simulations for a specific current and then gave the transverse impedance kick. This way horizontal oscillations didn’t reach to equilibrium as I expected too. Can you please suggest any correct and efficient way to implement this problem in elegant?
I’ve attached the files for your reference.
Thank you,
Aamna
test.zip
(17.33 KiB) Downloaded 273 times
Contact:
Re: Implementation of bunch lengthning and transverse impedance
Post by michael_borland » 26 Feb 2021, 13:50
Aamna,
Attached is an example of how to do this, using your lattice file. In brief, you should use ILMATRIX for such tracking as it is much faster and has sufficient physics.
Here are some beam parameters vs pass number
Here are the same parameters averaged over the last 500 turns vs charge
example.zip
(14.51 MiB) Downloaded 296 times
Aamna_Khan
Post by Aamna_Khan » 08 Mar 2021, 14:29
Thank you Michael!
Aamna
SDastan
Post by SDastan » 27 Jul 2022, 08:35
Dear Michael and all,
I try to simulate the microwave instability by tracking in Elegant but I can't find any logical result by changing the current from 0 to 6 mA. I used ZLONG by these parameters:
Rs=0.8 (ohm), f=7MGH and Q=1. It seems that the tracking doesn't see any instability or I made a mistake but I don't have any bunch length or energy spread increasing. The unusual result is like this:
I attached my files too and it will be great if you can take a look at on it. Thanks in advance.
microwave_instability.zip
(328.51 KiB) Downloaded 100 times
Sara
Contact:
Post by michael_borland » 27 Jul 2022, 20:15
Sara,
At first blush, I guess it is because your 2-ps bin size is too large for a 6 ps rms bunch duration. Try 0.1 ps.
SDastan
Post by SDastan » 02 Aug 2022, 07:53
Dear Michael,
Thanks for your help. Finally, I increased the impedance budget and the resistive wall effect to achieve the logical behavior. But there is a question based on the result as I don't have the continuous increase in the energy spread, can I say that 2(mA) is a threshold current?
and is it acceptable that I do not have smooth behavior in the energy spread?
Regards
Sara
Contact:
Post by michael_borland » 02 Aug 2022, 09:26
Sara,
I'd suggest using more particles and finer spacing of the points in current. I'd hope that will give a clearer threshold.
SDastan
Post by SDastan » 02 Aug 2022, 11:01
Thanks Michael. I will try your suggestion. I have another question, I have some kind of handle in the bunch length during tracking. Can we consider them as microwave instability and is it usual that they disappear after some turns?
1000 Turns with 2 mA currents
4000 Turns with 2 mA currents
Regards
Sara
Contact:
Post by michael_borland » 02 Aug 2022, 11:16
Sara,
Unless the handles reappear, I wouldn't consider that MWI. It may just be the bunch settling into the rf bucket that is distorted by potential well distortion.
SDastan
Post by SDastan » 04 Aug 2022, 09:09
Dear Michael,
Thanks for the help. I increase the number of particles from 150,000 to 1,500,000 and it worked:) as below:
Based on the result can I announce 0.5 mA as the threshold current? Also, I try to know how the beam behaves in MWI. For this, I plotted t,p from the watch file for each current as below in different steps. Is it correct if I consider the change in the behavior of the beam in the plot as MWI?
Regards,
Sara
Post Reply
