Issue with non-monotonic distribution supplied to sddssampledist
Posted: 05 Feb 2020, 08:39
Hi there,
I am trying to generate a customised distribution using sddssampledist but I am receiving the following error:
"random variate values not monotonically increasing for t_dist_400nm.sdds"
The distribution I am trying to create is a flat-top distribution with a sinusoidal modulation of a given wavenumber applied. This central distribution is flanked by two half-Gaussian tails, which are truncated to 4*sigma. This distribution is indeed non-monotonic, so I was wondering if there are any alternate methods within the sddstoolkit that will allow me to sample from this custom distribution. I have attached the relevant distribution file from which I attempt to sample. Here is an example of the command I use to sample the distribution:
sddssampledist t_dist_400nm.sdds my_dist.sdds -samples=1000000 -columns=indep=u,df=F,output=t,units=s,factor=1,offset=0
Any help you can provide with this would be greatly appreciated!
