2 laser and one wiggler
Post Reply
cloud9
Post by cloud9 » 13 Sep 2010, 01:05
Hello all,
I want to use 2 laser and one wiggler for electron beam modulation by laser.
When i see LSRMDLTR section in elegant code, i found only one laser and one wiggler is used.
Can we use two or more laser in one wiggler through this code?
Kumar
Contact:
Re: 2 laser and one wiggler
Post by michael_borland » 15 Sep 2010, 09:06
Kumar,
At this point, only one laser is supported. We'll try to add two-laser support in a future release.
Meanwhile, I can suggest two alternatives:
1. Use a sequence of two LSRMDLTR elements separated by an EMATRIX element that transports the beam to the beginning of the first LSRMDLTR. If you use matrix_output's printout option, you can get the matrix for your LSRMDLTR. Just form the reverse matrix and insert that as an EMATRIX.
2. Write a program that performs tracking through a laser modulator with two lasers. Use elegant's SCRIPT element to incorporate it into the beamline.
Post Reply
