Dear Michael,
I am trying to plot amplitude-dependent tune shift using TwissCalculation.
I calculated amplitude-dependent tune shift manually by using the tracking script. I found the tune in different y and constant x and vice versa, but the points are limited.
I am going to find ADTS in x=-20mm to x=+20mm and y=-10mm to y=+10mm. I applied it to ele file by x0 and x1 and y0 and y1.
I have attached my files. Could you give me a comment?
Thank you in advance,
Best regards
ADTS calculation
ADTS calculation
- Attachments
- ADTs.rar
- (1.58 KiB) Downloaded 102 times
- Contact:
Re: ADTS calculation
As the manual states: "this command is deprecated, because it is too difficult to tune it to get reliable answers. The use of driving term computation in twiss_output is recommended instead, even though it doesn’t include all possibly relevant effects. For tune-spread calculations, the tune_footprint command provides more versatility. "
If you have looked at the data yourself and verified that the fitting is good, then I'd trust those results.
Thank you for your useful comments.
As you mentioned, I used the tune footprint script to find the tune vs. amplitude. There are two points:
1. I do not see why the trend of the plot of the tune footprint script is not reasonable!
2. I used another script in which I tracked particles and then found the tune using sddsnaff comment. The result is different from the tune footprint and is not reasonable, either.
Could you help me, please?
Regards
Regards
- Attachments
- ADTS2.rar
- (246.55 KiB) Downloaded 98 times
