defining my own wiggler field
Post Reply
Runfeng_Luo
Post by Runfeng_Luo » 28 Jul 2022, 08:19
I wish to simulate the coherent betatron radiation with a plasma undulator, as described in 'Plasma Undulator Based on Laser Excitation of Wakefields in a Plasma Channel' by S. G. Rykovanov et al. I took a look at the manual, but it seems that I can one define the parameters for the wiggler/undulator. Is it possible for me to define my own wiggler field in ELEGANT simulation?
Contact:
Re: defining my own wiggler field
Post by michael_borland » 28 Jul 2022, 16:08
There are several ways to define undulator/wiggler fields in elegant, starting from field maps
1. CWIGGLER accepts data defining the undulator field in terms of longitudinal and transverse harmonics.
2. BGGEXP accepts data defining the fields in terms of generalized gradient expansions.
3. BMXYZ accepts a 3D field map (Bx, By, Bz) vs (x, y, z).
CWIGGLER and BGGEXP model classical and quantum radiation emission in terms of the effect on the beam. However, this isn't going to give you the radiation field from an undulator.
Runfeng_Luo
Post by Runfeng_Luo » 29 Jul 2022, 03:05
ELEGANT is capable of simulating SASE FEL, right? Are you saying I can only obtain the effect the radiation does to the beam, but not the radiation spectrum?
Seb_Wilkes
Post by Seb_Wilkes » 01 Aug 2022, 10:02
Do wait on Michael to confirm or deny, but yes to my understanding the synchrotron fields must be calculated ourselves, however the effects on a travelling bunch (particles) is modelled by Elegant. I had been looking at this for myself and for a classical wiggler I think the solution is to take the phase-space data before it goes into the wiggler and use postprocessing software to calculate the ensuing synchrotron fields.
If I may add, for plasma channels you may be better using a PIC code? While the answer may well depend on what the lifetime of the plasma structure is, and how confident you are that you can model the magnetic field without a full simulation. In any case, I do know that in PIC codes there is increasing work in postprocessing the simulation data to get synchrotron fields. Some even do it as part of the PIC cycle.
Contact:
Post by michael_borland » 01 Aug 2022, 19:50
Runfeng_Luo wrote:
29 Jul 2022, 03:05
It can compute SASE FEL output using Ming Xie's parametrization. It is not a real simulation, just an approximate estimate. You need to use a code like GINGER or GENESIS (etc) for the real FEL simulations.
Contact:
Seb_Wilkes wrote:
01 Aug 2022, 10:02
Seb,
Yes, I think you have it right.
Runfeng_Luo
Post by Runfeng_Luo » 03 Aug 2022, 03:12
Cool, thanks for the clarification.
Post Reply
