Am I right with the assumption that floor coordinates are calculated from the values in the lattice file, i.e. before vary_element and error_element are applied? Only the alter_elements command is applied before floor coordinates are calculated?
Regards
Frank
floor_coordinates: vary_ele vs alter_ele vs error_ele
frank_stulle
- Contact:
Re: floor_coordinates: vary_ele vs alter_ele vs error_ele
Frank,
Yes, that's right. Also, floor coordinates are updated, but not written out, during optimization.
It would be a good thing to remove this limitation. I'll add it to my list. Meanwhile, you can use alter_elements and a script to get the same result. Please see the attached file for an example.
- Attachments
- varyFloor.tar
- (10 KiB) Downloaded 448 times
