Parmela to Elegant beam
Post Reply
Aamna_Khan
Post by Aamna_Khan » 13 Nov 2017, 09:15
Hello Michael,
Is there any way to change parmela output beam (x, xp , y, yp, phi, E) to elegant input beam (x, x', y, y', t, p) in elegant directly.
If I'm correct earlier there was something called parmela2elegant. But, now I'm not able to find it.
Additionaly, Is elegant safe option for 5 MeV particle tracking through RFCA (+25 MeV)?
Aamna
Contact:
Re: Parmela to Elegant beam
Post by michael_borland » 13 Nov 2017, 09:36
Aamna,
I'm not aware of a parmela2elegant program. If the parmela output is ASCII, it shouldn't be hard to write a translation script. Since I don't use parmela, I'll need a file to work with, so please upload something if you can.
As for 5 MeV beam in RFCA, it should be reasonable good if you set N_KICKS large enough (vary it until it converges). The limitation is that RFCA only has an idealized sinusoidal standing wave longitudinal field. The TWLA (Traveling Wave Linear Accelerator) element would be a better choice.
Aamna_Khan
Post by Aamna_Khan » 13 Nov 2017, 09:45
Thank you for your prompt reply.
Please find the attached input_beam.txt file from parmela.
Aamna
input_beam.txt
(4.21 MiB) Downloaded 200 times
Contact:
Post by michael_borland » 13 Nov 2017, 09:54
Aamna,
Can you tell me the units of the columns? Also, is W the kinetic or total energy?
Aamna_Khan
Post by Aamna_Khan » 13 Nov 2017, 09:58
Hi Michael,
x and y are in cm...xp and yp are dimensionless (px/p, py/p in parmela), phi is in degree.
W is kinetic energy.
/Aamna
Contact:
Post by michael_borland » 13 Nov 2017, 10:16
Aamna,
Try the attached parmela2sscript. It seemed to give reasonable results.
I'll add this to the distribution for the next release.
parmela2elegant.zip
(737 Bytes) Downloaded 168 times
Aamna_Khan
Post by Aamna_Khan » 13 Nov 2017, 11:20
Thank you Michael. In the mean time we did the same :).
PS: From last few days, whenever I tried to download something from elegant forum it is php instaed of zip or png file. To convert it into zip, I have to rename the file from .php to .zip. Is it something with server because I tried to download it on three different computers it's php?
Aamna
Contact:
Post by michael_borland » 13 Nov 2017, 12:05
Aamna,
I'm not sure what the reason for fhe file.php business might be. I'll ask someone who might know.
Aamna_Khan
Post by Aamna_Khan » 15 Nov 2017, 09:03
Hi Michael,
During analyzation of twiss parametrs, I get to know that in parmela xp and yp are in [mrad]. Please correct it in parmela2elegant conversion before additing it to next release.
Aamna
Contact:
Post by michael_borland » 16 Nov 2017, 23:27
Aamna,
Thanks for the correction. The new version is attached and will be distributed with the next release.
parmela2elegant.zip
(751 Bytes) Downloaded 159 times
Post Reply
