Yue,
Try "make clean" before "make MPI=1".
run_setup very slow for very long beam line.
- Contact:
Re: run_setup very slow for very long beam line.
Now Pelegant works like a charm.
Thank you very much and have a nice weekend.
Yue
Yue
Hi, Michael
I am trying to track the long lattice many times, each varying some parameters. Is there a way of loop inside the command file without read the same lattice repeatedly, since it still takes seconds to read.
Thanks,
Yue
Thanks,
Yue
- Contact:
Yue,
Yes, this is possible using the &vary_element command. See
http://www.aps.anl.gov/Accelerator_Syst ... ode79.html
