Color density plots?
Post Reply
astecpete
Post by astecpete » 22 Mar 2012, 12:37
Hi Michael,
I've seen a few people showing sddsplot produced plots using color density to illustrate phase space distributions. Do I need to use sddscontour to make those or have I missed a feature in sddsplot?
Thanks
Peter
Contact:
Re: Color density plots?
Post by michael_borland » 29 Mar 2012, 11:09
Peter,
This is typically done with sddshist2d followed by sddscontour. E.g.,
sddshist2d phaseSpace.sdds phaseSpace.h2d -column=x,xp -xparam=100 -yparam=100
sddscontour phaseSpace.h2d -shade=100
You can use sddsplot for a similar effect, but only if you want to plot the points color-coded by a third phase space quantity, e.g.,
sddsplot -column=x,xp phaseSpace.sdds -split=column=t -graph=dot,vary -order=spect
will plot (x, x') color code by t.
dpe
Post by dpe » 12 Jul 2012, 04:20
I'have been playing a little bit with this but I do not like so much the final result.
Using shell distributions I have been able to produce some nice contour plots of the phase space of the bunch. Now I'd like to move my distribution parameters in order to get a contour for sigma, 2sigma, 3sigma... can this be done in a way similar to the one provided by the command vary_element, placing the distributions in different pages of the same SDDS file? Doing it manually would be quite tedious.
Tanks
dpe
Post by dpe » 16 Jul 2012, 02:53
Here is an example of what I would like to obtain:
Where different colours contain different percentages of the beam.
Using shell distribution I have been able to obtain just one of that contours, is there an easy and direct way to obtain many of them as in the example?
Thank you for your assistance.
Post Reply
