Transverse impedance element
Hi,
I am trying to use the ztransverse element to simulate the interaction between beam and transverse impedance.
would you mind explain me more about the data printed out with command
"wakes="%s.wake" in the %s.wake file?
Is the data Wx in file corresponds to wake potential obtained by Ifft(Zx(\omega) * \lambda(\omega) )?
And what is the <I_x> and <I_y> corresponding to ?
How the setting n_bins and max_n_bins are used in the code in simulation process?
your Chao
your Chao
- Contact:
Re: Transverse impedance element
Chao,
The Wx and Wy columns in the wake file are not the wake potential (IFFT of the impedance) but the wake field (IFFT of impedance convolved with the time-dependent moment of the current).
The Ix and Iy columns are the time-dependent transverse current-weighted moments of the bunch. More specifically, Ix is a histogram of Qi/dt*xi for all the particles i, using either the user-specified number of bins (N_BINS) or the number of bins implied by the number of points in the impedance file. dt is the bin spacing, which is derived from the impedance file or else the user-supplied BIN_SIZE parameter.
Dear Michael
Thanks for your kindly reply. It is very clear.
However, I am doing a test with elegant to get the wake field with a resistive wall impedance.
The lattice is a very simple which is drift + Trans_imp + drift.
If you do not mind, would you please take a look at the script in attached files.
In the Sbatch.sh file you can see what did I do.
It is found that the "wakes="%s.wtdrw" command does not give me the results expected.
Did I do something wrong in with my elegant files.
Great thanks.
yours Chao
#!/bin/bash
N_MP=(1000 10000 100000 1000000)
N_MP=(1000)
ele_file=USSRTracking.ele
Nscan=${#N_MP[@]};
for ((i=0;i<$Nscan;i++))
do
ncharge=1
nMP=${N_MP[$i]}
charge=`rpnl $ncharge 1.e-10 \*`
echo $i $nMP
elegant $ele_file -macro=root=${nMP}_MP,qin=${charge},Nparticle=${nMP}
done
sddsplot -layout=1,2 -leg=filename -graph=l,v -scale=0,100e-12,0,0 \
-col=Deltat,'(Wy)' *.wtdrw -mode=y=normalize -end \
-col=Deltat,'(Iy)' *.wtdrw -mode=y=normalize -end #\
-col=Deltat,'(Wx)' *.wtdrw -mode=y=normalize -end \
-col=Deltat,'(Ix)' *.wtdrw -mode=y=normalize -end #\
Great thanks.
yours Chao
#!/bin/bash
N_MP=(1000)
Nscan=${#N_MP[@]};
do
ncharge=1
nMP=${N_MP[$i]}
echo $i $nMP
done
- Attachments
- USSRTracking.ele
- (659 Bytes) Downloaded 3147 times
- RWIMP_AL_Power16_DCModifty_1.sdds
- (2.75 MiB) Downloaded 3284 times
- LatticeUSSRILMatrix.lte
- (681 Bytes) Downloaded 3242 times
- Contact:
Chao,
I'm not sure what you are expecting to see, but I wouldn't expect to see much because you are computing a transverse wake but your beam is centered on x=y=0. The only wake you'll see will be due to random offsets in <x> and <y> in the binning of the particle distribution.
Also, the frequency resolution of your impedance is very high, so you'll end up with a very long time span in the wake data, which may make the plots confusing.
Try adding some centroid offsets to you beam definition, e.g.,
When plotting, limit the time interval shown, e.g.,
Code: Select all
&bunched_beam
centroid[0] = 1e-3
centroid[2] = 1e-3
&end
Code: Select all
sddsplot -col=Deltat,Wx test1.wtdrw -filter=col,Deltat,0,1e-9
Dear Michael
It is very clear, I got that.
Thanks very much.
yours sincerely Chao
Thanks very much.
Dear Michael,
Sorry to bother you again. I met another problem to print out the transverse wakefield.
As shown in the *.lte file, I am trying to print out the longitudinal and transverse wake field in files "wakes="%s.wzrw" and "wakes="%s.wtdrw".
Whereas I found only the longitudinal wake field data "wakes="%s.wzrw" can be printed out. There is not data file "wakes="%s.wtdrw" given out by the elegant.
Did I make mistakes in the transverse impedance print out settings?
your sincerely Chao
your sincerely Chao
- Attachments
- test.tar
- (2.15 MiB) Downloaded 3149 times
Michael, by the way, how can I translate the wake potential data to the transverse momentum kick (for example in rad unit). Assume the beam is with <y> central offset?michael_borland wrote: ↑23 Aug 2021, 01:29Chao,
Try adding some centroid offsets to you beam definition, e.g.,Code: Select all
&bunched_beam ... centroid[0] = 1e-3 centroid[2] = 1e-3 &end
When plotting, limit the time interval shown, e.g.,--MichaelCode: Select all
- Contact:
If you have a wakefield from the ZTRANSVERSE element with the drive exponent = 1, then you just divide the value in the Wx or Wy column by the beam energy in eV to get the kick (change in slope).
