Coupling with ILMatrix element
Posted: 14 Jan 2019, 10:35
Hi all,
I want to simulate IBS using the IBScatter element, but I would like to do it using ILMatrix to speed up the computations. However, I would also like to include coupling in the simulation and I am not really sure about the best way to do that.
I have attempted to introduce coupling in my lattice by giving a tilt to the quadrupoles and then calculate the ILMatrix using twiss_output, but if I have understood the manual correctly the output from twiss_output is only valid for negligible coupling and therefore the ILMatrix will not include the coupling correctly?
I have also understood from the examples that the parameters for ILMatrix could instead be determined from tracking, which might mean that this would include the coupling? Or is it the case that the ILMatrix element cannot include coupling and it has to be introduced into the simulation in some other way?
Anyone else that have attempted this and found a working solution?
Best regards,
Teresia
Best regards,
Teresia
