feedback for double RF systems
Posted: 20 Mar 2018, 14:19
Hi,
I set up feedbacks for both main RF and 3rd harmonic cavities, as showing in the attached file. However, particles are lost after tens of turns. BTW, this is just half of the current that the machine aims for. The way that I set up feedback for the third harmonic cavity is to hold the cavity's voltage and phase at its optimum value, which is calculated by formula. Can you please check what I did wrong ? thank you so much,
regards,
wencan
regards,
wencan
