TFBFirSetup to get the FIR coefficients in transverse feedback
Posted: 10 Mar 2022, 11:22
Dear Michael,
Recently I'm studying the transverse multi-bunch feedback and is using the script 'TFBFirSetup' from the elegant example 'APS-24Bunch-CBI'. I learned from elegant forum that this script is using T. Nakamura's Time-domain least squire fitting theory to get the N-tap FIR coefficients. However, when I read and tested the script 'TFBFirSetup', I have three questions:
1. Line 70-71 of the script, it defines N-term psik, and to my understanding, the script says psik=2pi*nu*k+dphi, and dphi=psiD-psiP+nu, so
psik = 2*pi*nu*k+nu+psiD-psiP, this is also what I see from the calculation result. Is it reasonable that here is a single 'nu' in 'psik' but not '2*pi*nu' ? I tried to use the script directly to generate the coefficient for my lattice but the result is unstable, then I changed psik to 2*pi*nu*k+2*pi*nu+psiD-psiP and the new coefficients in FIR become stable. So is it a typo in the 'TFBFirSetup' script or did I misunderstood something?
2. From Nakamura's paper, I see him using the BPM data from turn 0 to turn -N to fit a N+1 tap FIR filter. If I understand correctly, the elegant script 'TFBFirSetup' is using the phase advance from turn -1 to -N to fit a N-tap filter. This is seen from psik = 2*pi*nu*(k+1) if my understanding in question 1 is correct. I also tried to use the 0 to -N+1 turn phase advance psik = 2*pi*nu*k to fit the coefficients but the result is unsbale. So is there any convention in elegant, like TFBPICKUP gets the data from the previous turn?
3. In the elegant manual I see it says it requires sum of coefficients ai to be 0 for TFBPICKUP, that's also what it's shown in the warning. But in the example I saw it's always the case that the TFBPICKUP sets only a0=1. And it doesn't cause any problem in my tracking too. So is it okay to just set a0=1 in TFBPICKUP?
Hope I described my questions clearly. Many thanks for your help.
Best regards,
Siwei
Best regards,
Siwei
