how to compute the emittance of a ring with wiggler located in vertical dispersion bump
Posted: 28 Jun 2021, 06:49
Hi Michael,
I add a small vertical dispersion bump (several CSBEND elements with TILT=pi/2) in a ring and put a horizontal wiggler to this vertical dispersion bump. I try to use &moments_output to evaluate the equilibrium vertical emittance. Should I include classical, single-particle synchrotron radiation in wiggler to get accurate values? I found that when I included it, the emittance increased a lot.
--Weihang
--Weihang
