Hi Michael,
When i use "TAPERAPE" as the aperture element, it's not clear why the particle lost in "TAPERAPE". Attached the files. Could you check and give some suggestion? Thank you!
Best regards,
Cai
Why are particle lost in "TAPERAPE"
- Attachments
- Run_step2.ele
- (1.16 KiB) Downloaded 171 times
- lattice_V1.lte
- (4.97 KiB) Downloaded 176 times
- loss.png (6.92 KiB) Viewed 4734 times
- Contact:
Re: Why are particle lost in "TAPERAPE"
Cai,
The problem is this TAPERAPC element
There's a bug in the code that causes all particles to be lost when RSTART=REND. You can work around this by replacing the TAPERAPC with an ECOL, or changing RSTART to be slightly different from REND.
I'll fix the bug in the next release. Thanks for reporting the problem.
Code: Select all
BS1TPR4: TAPERAPC, L=0.07500000,RSTART=0.03150000,REND=0.03150000,STICKY=1
Hi Michael,
Thanks. Get it.
Best regards,
Cai
Thanks. Get it.
Best regards,
Cai
