Transient beam loading with passive Harmonic cavity
Dear All,
I want to see the effect of different filling patterns on the bunch length in presence of passive harmonic cavity for my case. Just to start with, can any one help me and share some example files.
regards
D K Tyagi
regards
D K Tyagi
- Contact:
Re: Transient beam loading with passive Harmonic cavity
Please see the attached files, which show how to simulate 4 trains of 12 bunches with main and harmonic rf cavity beamloading.
Some sample output --Michael
Sir,
Can you please share some input files where bunch lengthening with different filling pattern are calculated.
regards
regards
- Contact:
Please try the attached files.
There's a README file that gives some guidance. The script generateBunchTrain is used to make the fill pattern.
- Attachments
- transientBeamLoading.zip
- (2.76 MiB) Downloaded 1695 times
Dear Dr. Borland,
I use elegant example file "touschekWithHHCFromTracking" for simulation of Touschek beam lifetime with a parasitic 4th-harmonic RF cavity and got results. In this example "generate bunch train" command is not used. Can you please send example file in which bunch train command is used for simulation of bunch length and Touschek lifetime simultaneously in bunch trains?
Thanks,
Pradeep Kumar
Thanks,
Pradeep Kumar
- Contact:
Pradeep,
I can't find that example. Can you post it?
Dear Dr. Borland,
Please find attached example file for simulation of Touschek lifetime in presence of passive harmonic RF cavity which I received from you earlier. I want to study Touschek lifetime with uniform and non uniform RF buckets fill, due to transient beam loading, bunch length will be different in bunch train along the beam path. In non uniform fill due to different bunch length, bunch-by-bunch Touschek lifetime will be different. Please help me how to simulate bunch-by-bunch bunch length and Touschek lifetime using generate bunch train command.
Thanks and regards,
Pradeep
Thanks and regards,
Pradeep
- Attachments
- touschekWithHHCFromTracking.tar.gz
- (1.97 MiB) Downloaded 1514 times
- Contact:
Pradeep,
Please see the attached file for an example.
- Attachments
- touschekWithHHCFromTracking-nonuniformFill.tar.gz
- (1.69 MiB) Downloaded 1481 times
Samira.kasaei
Dear Michael,
I am trying to run the script for harmonic cavity. I got the error while I run ./setUpCases as below:
./setUpCases: line 5: setUpCase: command not found
Done preparing job scripts
ls: cannot access run-*.csh: No such file or directory
Could you please lets me know how can I solve this?
Thank you in advance,
Samira
Samira
- Contact:
Samira,
It might be because your path does not include your present working directory. You can either add it to your path, or modify setUpCases as to change "setUpCase" to "./setUpCase".
