Dear Michael,
I calculated DA and FMA for a bare lattice and lattice with ID.
But I found DA is increased after adding ID! What is wrong in my calculation?
I attached my files. I do appreciate if you can take a look to my files.
Best regards,
Samira
FM
Samira.kasaei
FM
- Attachments
- FMA-zip.tar.gz
- (254.83 KiB) Downloaded 796 times
Samira.kasaei
Re: FM
Dear Michael,
I had a basic question.
Concerning frequency map analysis, when do we introduce these parameters: delta_min, delta_max and ndelta?
Many thanks for your reply,
Samira
Samira
- Contact:
Re: FM
Samira,
You would introduce those if you want to perform FMA as a function of (x, delta) or (y, delta). For example, for (x, delta), you'd use something like
Code: Select all
&frequency_map
output = %s.fma,
xmin = -0.01, xmax = 0.01, nx = 21,
ymin = 1e-6, ymax = 1e-6, ny = 1,
delta_min = -0.04, delta_max = 0.04, ndelta = 21,
include_changes = 1
&end
