Transverse phase space
Post Reply
Samira.kasaei
Post by Samira.kasaei » 13 Mar 2022, 06:24
Dear Michael,
I wanted to plot transverse phase space for 1000 particle tracking. I did track and I introduced watch elements. I need to plot a profile as it is in the attached file.
can you give me some hints?
Best regards,
Samira
Samira.kasaei
Re: Transverse phase space
Post by Samira.kasaei » 13 Mar 2022, 07:36
Here are my files.
I forgot to add them.
input2.sdds
(13.36 KiB) Downloaded 4648 times
STORAGE.lte
(3.7 KiB) Downloaded 4678 times
track.ele
(1.53 KiB) Downloaded 4641 times
Contact:
Post by michael_borland » 16 Mar 2022, 16:26
Samira,
See the attached files.
track.ele
(849 Bytes) Downloaded 4702 times
STORAGE.lte
(3.84 KiB) Downloaded 4663 times
Samira.kasaei
Post by Samira.kasaei » 17 Mar 2022, 02:58
Dear Michael,
Many thanks for reply.
I have three questions. I do appreciate if you answer me.
Why did you choose line distribution for the beam ?
If I set center_on_orbit to zero I don't see any difference in the results.
I am going to plot x-y space also, How can I do it?
Many thanks and best regards,
Samira
Contact:
Post by michael_borland » 18 Mar 2022, 12:44
Samira,
Samira.kasaei wrote:
17 Mar 2022, 02:58
This provides a nicer starting point for phase space plots because all the particles are arrayed on a line with equal spacing
17 Mar 2022, 02:58
center_on_orbit defaults to 0. You should only see a difference if you set center_on_orbit=1, which causes the &track command to suppress the centroid offset from the &bunched_beam command. This changes the initial particle coordinates from spanning [0, 20 mm] to spanning [-10mm to +10mm].
17 Mar 2022, 02:58
There's no simple answer to that. If you have cross-plane coupling, vertical motion will appear automatically. You can also prepare a beam along a line in x-y space (do this with a separate run using a MALIGN element with covariation of DX and DY).
-Michael
Post Reply
