Dear All,
I am running a very simple example with the track command.
The output is different between elegant and Pelegant.
elegant mytest.ele produce mytest.w1 as expected
mpirun -n 2 Pelegant mytest.ele does not produce any mytest.w1 file.
Could you please explain why ?
Is this a bug ?
Best regards,
Laurent.
WATCH element Pelevant vs Elegant behavior
- Contact:
- Attachments
- mytest.tgz
- (2.28 KiB) Downloaded 141 times
- Contact:
Re: WATCH element Pelevant vs Elegant behavior
Laurent,
The problem is that you are asking to do parallel tracking with only 1 simulation particle. It is a bug, I think, but perhaps an understandable one.
If you increase the number of particles to at least equal the number of cores, it will be fine. Typically to get a benefit from parallel tracking you should use "many" particles per core. Otherwise, interprocess communication may negate any benefit from parallelism.
How many you need to get a benefit will depend on the particular simulation.
- Contact:
It was working nicely in the past.
Thanks Michael for the quick answer.
Now I now how to modify my code.
Laurent.
Laurent.
