Tune difference between MADX and ELEGANT when we have decouping section?
gwei
Re: Tune difference between MADX and ELEGANT when we have decouping section?
Post by gwei » 15 Mar 2018, 15:56
Thank you, Michael,
But even with emittances_from_twiss_command = 0, there is no output also.
Guohui
michael_borland wrote:
15 Mar 2018, 15:49
Guohui,
Sorry, my mistake. Add
Code: Select all
to the &coupled_twiss_output command.
DAkwithDetectortune.ele
(923 Bytes) Downloaded 516 times
Contact:
Post by michael_borland » 15 Mar 2018, 16:08
Guohui,
Yes, unfortunately there is a bug in the released version. I'll send you the output file from the development version, just FYI.
gwei
Post by gwei » 15 Mar 2018, 16:16
Hi Michael,
Thank you so much.
And I think Dynamic aperture is OK with coupling section for a ring lattice because &find_aperture(as follow) is based on track.
Is it right?
Thank you again.
guohui
&find_aperture
output = "%s-check.aper",
mode = n-lines,
n_lines = 41,
xmin = -0.0015,
xmax = 0.0015,
ymin = 0
ymax = 0.001,
nx = 21,
ny = 11,
n_splits = 8,
desired_resolution = 0.000001,
offset_by_orbit = 1,
verbosity = 1
&end
15 Mar 2018, 16:08
Guohui,
Contact:
Post by michael_borland » 21 Mar 2018, 16:00
Guohui,
The latest version of elegant , 34.2.0, fixes these problems and includes computation of the tunes for coupled motion.
Post Reply
