Different U0 utilizing CWIGGLER/GFWIGGLER/UKICKMAP?
Post Reply
Shichang
Post by Shichang » 07 Nov 2017, 21:47
Hi,all!
When I tried to replace the IDs from CWIGGLER to UKICKMAP,which I got from the example: cwiggler+kickmap.
However I found that U0 calculating by UKICKMAP is less than using CWIGGLER,and I also tried element GFWIGGLER,the result is similar to the
UKICKMAP.
Is this a normal result?Or I have to make some changes in producing input_file of ukickmap?
Thanks!
Shichang
Contact:
Re: Different U0 utilizing CWIGGLER/GFWIGGLER/UKICKMAP?
Post by michael_borland » 08 Nov 2017, 16:31
Shichang,
If you could provide files that show the problem, that would help.
Shichang
Post by Shichang » 08 Nov 2017, 20:12
Here is my lattice file and the .ele file.
The compressed files are the kickmap.sdds for the IDs,described by CWIGGLER are added in the lattice file.
Thanks for your timely respond!
Shichang
ukickmap.rar
(240.35 KiB) Downloaded 836 times
lattice_FO.lte
(53.59 KiB) Downloaded 832 times
injection.ele
(1.57 KiB) Downloaded 857 times
Contact:
Post by michael_borland » 09 Nov 2017, 16:21
Shichang,
I think it was a matter of not setting the parameters to the equivalent values. See the attached files. I get very good agreement.
After unzipping the file, change to the 2017-11-09 directory, copy in the kickmaps, and then type "runScript" to execute the test.
2017-11-09.zip
(10.25 KiB) Downloaded 864 times
Post Reply
