implementation of wake potentials generated by a Gaussian bunch
Posted: 06 Mar 2019, 08:36
Dear all,
I want to implement wake potentials which I got from the software ECHO. ECHO uses a Gaussian source bunch to calculate the wake potentials. The results from ECHO for an example pillbox cavity and an example Gaussian bunch with sigma=1 mm are plotted below:
As you can see, the (converted) output from ECHO is longitudinal distance relative to the center of the Gaussian bunch vs. wake potential in V/C (longitudinal, mode 0) and V/C/m (transverse, mode 1) respectively, plotted in blue. As a reference, you can find the Gaussian bunch with sigma=1 mm in the plot (arbitrary y-axis), plotted in red. I am not sure if my wake potentials are the "integrated wakes" one can import via the elegant elements WAKE and TRWAKE (maybe I have to change the sign of the longitudinal one, since in the manual is written "A physical wake function should be positive at t = 0").
My question is: how do I implement these wake potentials correctly, because in the manual is written "The values of the time coordinate should begin at 0", but since I use a Gaussian bunch instead of a point charge, I get a more complicated distribution as you can see from the plots. In particular there are negative time coordinates (with reference to the center of the Gaussian bunch). A comment like "test particle behind the wake-potential-generating particle" is not easy in that case, since the wake is not generated by a single point charge. There is only a comment like "test particle relative to the center of the wake-potential-generating bunch" possible.
Thanks,
Amelie
Thanks,
Amelie
