error: Less than 2 bins for CSR
Posted: 04 Jan 2018, 10:25
Dear Michael,
I was often getting the following error when using CSRCSBEND (see attachements):
After some playing around I found out, that if I replace INTEGRATION_ORDER = "order_integration" by INTEGRATION_ORDER = 2, the error is gone!
So variable definition refuses to work, but strangely enough, only for this parameter!
Am I doing anything wrong?
Thanks!
Slava
Code: Select all
error: Less than 2 bins for CSR!
Program trace-back:So variable definition refuses to work, but strangely enough, only for this parameter!
Thanks!
Slava
