error: Less than 2 bins for CSR
libov
Post by libov » 04 Jan 2018, 10:25
I was often getting the following error when using CSRCSBEND (see attachements):
error: Less than 2 bins for CSR!
Program trace-back:
After some playing around I found out, that if I replace INTEGRATION_ORDER = "order_integration" by INTEGRATION_ORDER = 2, the error is gone!
So variable definition refuses to work, but strangely enough, only for this parameter!
Am I doing anything wrong?
Thanks!
Slava
csr_test.lte
(584 Bytes) Downloaded 609 times
csr_test.ele
(816 Bytes) Downloaded 629 times
Re: error: Less than 2 bins for CSR
Post by michael_borland » 08 Jan 2018, 08:58
Slava,
I tried your files and they worked fine. Can you confirm that you are using the latest version?
libov
Post by libov » 08 Jan 2018, 09:47
indeed I was using 33.1.1 !
After I updated to 34.0.1 everything works.
However I'm anyway a bit puzzled, since the .lte/.ele files I'm using are a few years old (not those I've sent you as examples), so even elegant versions older than mine should work....
Anyway, main thing it works now!
Thanks!
Slava
Post by michael_borland » 08 Jan 2018, 10:58
Slava,
Thanks for letting me know.
It's quite possible that we introduced a bug, then fixed it, which would explain why the files used to work.
