smoothDist6s error
tcharles
smoothDist6s error
Post by tcharles » 08 Jun 2017, 22:59
I'm getting the following error message when using smoothDist6s:
smoothDist6s -input ./output/xfelfodo.out -output ./output/xfelfodoSLICE.out -betaSlices 10 -factor 2
Error1: couldn't execute "sddspfit": no such file or directory
However sddspfit seems to be working fine. For example, this works fine:
sddspfit ./output/xfelfodo.out ./output/endoflinac.fit -terms=12 -evaluate=./output/endoflinac.eval,number=10000 -column=t,p works
Do you know what the problem could be?
Thanks for you help,
Tessa
Re: smoothDist6s error
Post by soliday » 26 Jun 2017, 11:22
What operating system are you using? If it is a form of linux, what do you get when you type "which sddspfit".
