link_elements
Posted: 23 Mar 2015, 08:44
Dear Elegant users and experts,
we had some problems using link_elements and I hope to find some help here in the forum.
Many of the quads in our beamline are split in two halfs in order to be able to position a marker in the center (the markers represent strip line BPMs). The two halfs are indicated with the suffixes .U (upstream) and .D (downstream). The plan was to link the strength of the second half of the quad to the strength of its first half.
It turned out that the quadrupole strength is correctly listed in the parameter file (which I get from run_setup) after the elegant run. However, when I plot the twiss functions using sddsplot, it is clearly visible that the second half of the quads is still set to K1 = 0 (as it is by default).
Did I do something wrong in my files?
I would appreciate if you could help me to solve this problem.
Best, Matthias
Best, Matthias
