Big difference results between KQUAD and QUAD
Post Reply
Cai_Meng
Post by Cai_Meng » 14 May 2021, 03:45
Dear Elegant experts,
when I designed an achromatic lattice, there are big difference results between KQUAD and QUAD lattice with "default_order=3". Although, two lattice have same "etay" (*.twi) , the simulation results with QUAD-lattice looks good, but the simulation results with KQUAD-lattice show that the R36 sames not zero (*.sig & *.out). The results and lattice file are presented as attachments. Could you give me some suggestions? Are there some unreasonable settings ?
Thank you very much!
Best regards,
Cai
Results.rar
(25.39 KiB) Downloaded 368 times
QUAD.rar
(2.12 KiB) Downloaded 383 times
KQUAD.rar
(2.12 KiB) Downloaded 375 times
Contact:
Re: Big difference results between KQUAD and QUAD
Post by michael_borland » 14 May 2021, 10:53
Cai,
You need to use more slices for the KQUAD elements to get accurate integration. The defaults are rarely sufficient.
Try changing
Code: Select all
KQUAD,...
to
Code: Select all
KQUAD,INTEGRATION_ORDER=6,N_SLICES=10,...
I did this and the agreement on s36 was essentially perfect.
Cai_Meng
Post by Cai_Meng » 16 May 2021, 20:29
Hi Michael,
Thanks very much! It does work after increasing the value "N_KICKS".
Best regards,
Cai
Post Reply
