About the parameters of CSBEND
Post Reply
Cai_Meng
Post by Cai_Meng » 26 Apr 2020, 03:47
Dear Michael,
For the parameter file (& run_setup parameters=%s.para), there are 73 and 74 parameters of CSBEND without and with "&error_element" command (even without CSBEND errors). The difference is ETILT_SIGN. Is there some different in this two case?
Thanks in advance!
Best wishes,
Cai
Contact:
Re: About the parameters of CSBEND
Post by michael_borland » 05 May 2020, 18:21
Cai,
Perhaps you are looking at output from two different versions of the code? The ETILT_SIGN parameter was added recently.
Cai_Meng
Post by Cai_Meng » 18 May 2020, 19:35
Dear Michael,
I have tried different versions, the elegant-2020.2 have this difference, as you said, this is a new parameter.
Best regards,
Cai
Post Reply
