what's wrong with simulation of transport line orbit correct
Post Reply
shancai
Post by shancai » 23 Oct 2009, 03:33
hello,
The reference orbit have a change and is not zero.
I don't know what's the reason.
Thank a lot!
HLS2.ele
(3.22 KiB) Downloaded 806 times
new53.lte
(2.94 KiB) Downloaded 773 times
Contact:
Re: what's wrong with simulation of transport line orbit correct
Post by michael_borland » 28 Oct 2009, 16:35
Shancai,
I ran your simulation but get a different result, which is attached here.
Can you tell me which version of elegant you are using? The one-to-one trajectory correction was updated in the last release, so it might make a difference.
shancai
Post by shancai » 29 Oct 2009, 04:00
I use the newest version elegant(22.0.1).The attachment is the log file.
hls2.log
(596.63 KiB) Downloaded 757 times
Contact:
Post by michael_borland » 29 Oct 2009, 14:30
Shancai,
I don't see any obvious problems in the log file. Can you make a tar file of all the output files and post it?
Also, what operating system? 32 or 64 bit?
Thanks--Michael
shancai
Post by shancai » 29 Oct 2009, 19:20
Thanks a lot!
My system is 32 bit fedora 11
hls2.zip
(922 KiB) Downloaded 822 times
Contact:
Post by michael_borland » 29 Oct 2009, 20:29
Shancai,
I can confirm that there is a problem with your simulation for recent versions of elegant. The reason is that you are using CSBEND elements with the default integration parameters. These defaults are not good for most cases (this changes in the next release).
Try setting N_KICKS=12,INTEGRATION_ORDER=4 on all the CSBEND elements. It should fix the problem.
shancai
Post by shancai » 06 Nov 2009, 21:10
Thanks a lots!
It works.
Post Reply
