Energy loss due to CSR
Post Reply
tennant
Post by tennant » 09 Sep 2009, 07:23
Hi,
Is there a preferred method for monitoring the energy loss due to CSR through a chicane? Thanks.
--chris
Contact:
Re: Energy loss due to CSR
Post by michael_borland » 09 Sep 2009, 08:24
Chris,
There are two main options:
1. In run_setup, use the centroid parameter to specify the name of a file to which centroid information will be written. The relevant quantity is Cdelta, defined as <p>/pCentral-1.
2. Add several WATCH elements with mode="coordinate" to see the change in the particle distributions, including energy loss. For example, you could add a WATCH element before and after each dipole.
Post Reply
