Large discrepancy between ECNX & ENX
Post Reply
Zamank
Post by Zamank » 02 Sep 2014, 16:42
Hi All,
Pretty curious over some odd data. I basically have some accelerating structures and a chicane (standard 4-dipole), despite the fact that the dispersion is cancelling at the end of the chicane the ENX>>ECNX.
Any ideas of what could be causing the discrepancy between the ecnx and enx?
help.lte
(30.14 KiB) Downloaded 510 times
help.ele
(1.87 KiB) Downloaded 477 times
Contact:
Re: Large discrepancy between ECNX & ENX
Post by michael_borland » 16 Sep 2014, 11:42
Sorry for the delayed reply. I was on vacation.
The problem is that although the dispersion is nominally cancelled, CSR kicks inside the chicane introduce correlations between x and delta. This probably originates in the last two dipoles, where the bunch is short. See attached plots.
Zamank
Post by Zamank » 19 Nov 2014, 17:52
Hi Michael,
So, the ECNX over compensates and subtracts off these CSR-induced correlations? Am I correct in stating that in this case ENX would be a more accurate depiction of the transverse emittance?
Thanks
Contact:
Post by michael_borland » 05 Dec 2014, 05:05
Yes, that's right. ECNX is just the ideal value you'd get if you somehow managed to remove all the correlations.
Post Reply
