question on ECOL and RCOL
Post Reply
Philippe Piot
Location: Northern Illinois University & Argonne National Laboratory
Contact:
Post by Philippe Piot » 21 Aug 2008, 06:20
Hi,
Are ECOL and RCOL always centered on the reference trajectory? When I insert
such a collimator in a dispersive section, I loose most of the particles.
Thanks for any help.
-- Philippe.
Attachment: example; see .png pics for with and without collimator cases
COL.tar
(200 KiB) Downloaded 597 times
Contact:
Re: question on ECOL and RCOL
Post by michael_borland » 21 Aug 2008, 08:26
Philippe,
By default, collimators are centered on the reference trajectory.
The problem I see with your run is that p_central=26.19 in run_setup, but sddsanalyzebeam tells me that your beam has <p> = 22.98. So when the beam goes through the chicane, it has a large trajectory offset and hits the collimator.
An easy way to prevent this kind of error is to let elegant determine p_central for your beam using the "expand_for" feature:
&run_setup
expand_for = <beamFileName>
&end
It is a little inefficient in that the beam file is read twice (once by run_setup and once later by sdds_beam). However, that isn't a worry unless the beam file is huge.
Post Reply
