sddsplot libpng issue
Posted: 25 Oct 2017, 21:38
Hi,
I'm facing an annoying problem with sddsplot. I built SDDS 3.5.1 and ELEGANT 33.1.1 from source on a RHEL 6.5 server, everything works perfectly except when I want to save a plot using the png device. To be more specific, when I run the following command
I get the following warning and the plot is not saved successfully.
libpng warning: Application built with libpng-1.2.49 but running with 1.6.10
gd-png error: cannot allocate libpng main struct
It would be highly appreciated if anyone can help on this issue!
Best,
Zhe
Best,
Zhe
