cygwin and oagtclsh error
Posted: 21 Mar 2017, 08:49
I am trying to run "boosterramp" sample file which I also attached. It did not work on windows and I tried to run it with cygwin; and to be sure that cygwin and elegant works well, I tested it with twis calcularion and having plot, it works. so I am sure that cygwin and elegant is there and working well.
hovewer, when I start to run boosterramp file, I had a problem as I explained below;
I am doing what it writes in "notebook" document which is also attached;
- I write "elegant BYBL0.ele" to the command line ant it gives a twi file as an output.
- Hovewer, when I write "computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25" to command line, it gives an error and writes; "there is no oagtclsh".
I would appreciate if you could help me to figure it out.
