sddsplot on Max OS X
Jibong
Post by Jibong » 23 Feb 2017, 11:25
Hello.
I have installed elegant(the latest darwin-x86_elegant.tar.gz) on OS X Yosemite(10.10.5).
Calculation has run smoothly, but a plot cannot be obtained. I used XQuartz(2.7.11).
When I tryed to sddsplot, I got an error message:
$ sddsplot a.twi -col=s, betax
$ Warning: Fatal Error:_XmGetDefaultDisplay cannot be used prior to VendorS.Initialize, returns NULL
I want to know how to plot the data.
Any help would be appreciated.
Thanks and cheers,
Re: sddsplot on Max OS X
Post by soliday » 23 Feb 2017, 11:57
You will need to set the environmental variable DYLD_LIBRARY_PATH to /opt/X11/lib/flat_namespace to get this to work.
export DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace
XQuartz changed libXt to a two-level namespace library. This is incompatible with openmotif applications which require this workaround. I will put this information next to the download link.
Jibong
Post by Jibong » 23 Feb 2017, 15:11
Thank you very much for your prompt reply.
After setting the environmental variable you said, it's working perfectly.
Thanks again!
