geneticOptimizer problem
Xavier Nuel
Post by Xavier Nuel » 10 May 2013, 08:30
Hi everyboby,
I am trying to follow the GuideToUse to run the examples of moga. I have a error when I write the command geneticOptimizer -input optim1.sdds -reduce 1
Input file read and checked.
Error: optim1.all file found but -contin 1 not given
However it runs when I put -contin in the command. Why the programs wants to continue optimizing from a previous run if I am the beginning of the optimization?
Xavier
NicolaCarmignani
Re: geneticOptimizer problem
Post by NicolaCarmignani » 13 May 2013, 02:25
Hi Xavier,
if in the directory there is the optim1.all file, you have to put the -contin option. If it is the first run, you have to delete the optim1.all file.
Xavier Nuel
Post by Xavier Nuel » 13 May 2013, 04:42
Hi Nicola,
Thank you very much!!
